Matching Bank Data
Hi All,
Just wondering if in the Match Bank Data section there is a way to bulk tick the transactions listed in the Account Transactions window.
Thanks
Sorry about the late reply. Unfortunately no. But, you can try checking on the boxes and then holding shift down and checking a box after a few lines below and see if it obeys that shift command.
